Inbox all White
  • 6 views
  • Last reply by Toad-Hall
My inbox is all white, I cannot see the list of all my emails however I can see the message when I click into each message. When I click on my other folders I can see everything normally.
Attached screenshots
I notice all the column headers seem to gone as well. It seems you have an invisible list.
Select another folder which shows all the column headers. Click on the far right column header selection icon at the bottom of dropdown menu select 'Apply column s to' > 'Folder and it's children' > select name of account > select name of account.
Then select the Inbox Report on results.
